Sean-bumble-bee
Flight distance : 15997 ft
Thanks.
I see I have made a mistake.
I downloaded a fresh set of logs from my FPV goggle and, what the PH csv coinsiders to be the DAT number, is the middle group. So the crash DAT, if it exists, would have a name something like
FLYxyz-063-20240707hhmmss.DAT
That said, did you add the .enc bit in those file names ? I doubt it but .....
Unfortunately CsvView can not read either of your DATs BUT as a consequence of your post I have just checked the above logs.
I downloaded the logs, from my FPV goggles to three phones. each phone was running a different versions of the fly app, those version are
1.3.0
1.4.4
1.12.8
The DATs shown in 1.12.8 have the .enc extension and CsvView CAN NOT read them.
BUT CsvView CAN READ the DATs from 1.3.0 & 1.4.4 and those DATs DO NOT have the .enc extension.
If you want to see/check the motor RPMs, below is a scary rpm snippet from my FPV logs, it might be worth your trying the following which assumes you have an android phone or access to one.
1) MOVE all the fly app logs from the phone to computer.
2) Either uninstall the existing, at a guess, recent FLY app version and install an older version of the fly app on the phone or install an older version of the fly app on another phone.
Older versions of the app are available from
https://www.apkmirror.com/apk/dji-technology-co-ltd/dji-fly/
perhaps start at 1.3.0
3) Once it is installed AND BOOTED switch the phone's WiFi OFF.
4) Try 1.3.0 and see what it downloads from the goggles. If 1.3.0 won't work with your goggles then try a later/younger version of the app.
If you succeed in getting DATs without the .enc extension try CsvView
https://datfile.net/CsvView/downloads.html
and see if it can process the DATs or upload them to another page on SwissTransfer.
