Goggles 3 & 03 Air Unit Seems to go FARTHER!?
255 4 7-30 19:29
Props
Flight distance : 3809872 ft
Am I just nuts or is anyone else noticing that the new Goggles 3 update that allows you to connect to the 03 Air Unit means the 03 Air Unit can go much farther before breaking up? I fly around my house a lot and I use to only be able to fly about 3 houses down and now I can go at least 6 houses before the video breaks up. Is anyone else noticing this? Can DJI please chime in as to whether this is technically true?I haven't yet tested it where I can really push it but I'm interested in hearing if anyone else is noticing this.
7-30 19:29
DAFlys
Drone Wilder did a review of the goggles 3 and O3 and he said the range was terrible.
7-31 00:15
Props
DAFlys Posted at 7-31 00:15
Now I'm really curious! Maybe he got a bad pair or I got a great pair! But mine are definitely reaching out farther than they did before. I will report back after I get a chance to really test a long flight that I've done hundreds of times!
7-31 09:36
DJI Gamora
Hi there,
Thank you for reaching out. Yes, Max Video Transmission Range for DJI O3 Air Unit is 10 km (FCC), 2 km (CE), 6 km (SRRC).
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
7-31 22:11
Props
Drone Wilder was comparing his 03 with the Avata 2, not the Goggles 2 versus the Goggles 3. Also, I am FCC and he is in Europe so he can't legally use that. He did say that upon testing an FCC hack, he got far better distance and penetration. I get far better penetration and distance using the Goggles 3 with my 03 than I did with the Goggles 2 so I'm thrilled about it because I didn't expect it at all and I'm not sure why it is but it could be simply better antennas or some simple explanation.
8-1 17:17
