Version v1.00.0608
350 1 2024-8-3
wiwi76
Bonjour.
Nouveau en dji et pas tout jeune 55 ans, pas doué en informatique.je voudrais mettre la version @.00.0608 dans les lunettes dji fpv. 2 mais je ne sais pas comment faire.pourriez vous m aider svp.merci.
2024-8-3
DJI Susan
Hello. You can use DJI Fly or DJI Assistant 2 (Consumer Drones Series) to update the firmware.
(You can refer to page 66 of the user manual. https://dl.djicdn.com/downloads/ ... _Manual_v1.2_EN.pdf
1. Using DJI Fly
After powering on the aircraft, goggles, and remote controller, make sure that all devices are linked. Connect the USB-C port of the goggles to the mobile device, run DJI Fly, and follow the prompt to update. An internet connection is required.
2. Use DJI Assistant 2 (Consumer Drones Series) to update the aircraft, goggles, or remote controller separately.
(1). Power on the device and connect it to a computer with a USB-C cable.
(2). Launch DJI Assistant 2 (Consumer Drones Series) and log in with a DJI account.
(3). Select the device and click Firmware Update on the left-hand side.
(4). Select the firmware version required.
(5). DJI Assistant 2 (Consumer Drones Series) will download and update the firmware automatically.
(6). The device will restart automatically after the firmware update is complete.
Note:
1. Make sure to follow all the steps to update firmware. Otherwise, the update may fail.
2. The firmware update will take approximately 11 minutes. When updating the firmware, it is normal for the gimbal to go limp, and the aircraft to reboot. Wait until the update is complete.
3. Make sure the computer is connected to the internet.
4. Make sure that the device has sufficient power before updating firmware. Before performing an update, make sure the Intelligent Flight Battery is at least 43% charged and the goggles battery and the remote controller are at least 30% charged.
5. Do not unplug the USB-C cable during an update.
6. If there is an additional battery that needs to be updated after the update is complete, insert it into the aircraft and power on the aircraft. A prompt will appear in the goggles to update the battery. Make sure to update the battery before takeoff.
7. Note that the update may reset various flight parameters such as the RTH altitude and the maximum flight distance. Before updating, take note of your preferred settings and readjust them after the update.
2024-8-3
