Can the Avata 2 be used non-FPV using the FPV Controller 3 & iPhone
501 3 8-6 17:21
rotes.indie_0e
I reecently won an Avata 2 with Goggles 3, RC 3 and FPV controller 3. Here in Australia the rules around FPV drone usage outdoors is ridiculoulsy draconian (must have line of site or a trained spotter and be a memeber of a club at a club field etc..). Can the Avata 2 be used like a traditional drone, using an iphone and the controller, without the goggles?
8-6 17:21
ars.fabula
Flight distance : 3294711 ft
Switzerland
Yes, but not really (how's that for a confusing answer?)...
You can add a phone holder to the RC2 and connect the phone via USB (or wifi) to the DJI fly app. You have to keep the goggles around your neck or on your forehead as the signal of the RC2 goes thru the goggles.
The setup is not ideal and you want to avoid flying acro in this setup.
This is the phone holder I use: https://www.thorsdroneworld.com/ ... -holder-for-dji-fpv
8-6 21:20
bJako
Flight distance : 2353041 ft
Estonia
ars.fabula Posted at 8-6 21:20
I have seen great lag sometimes - even with USB cable!
And you can't fly FPV with 2 sec lag!
8-11 23:00
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Unfortunately, DJI Avata 2 must be used together with the goggles. You cannot use the drone alone with DJI RC Motion 3 or DJI FPV Remote Controller 3.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
9-4 00:22
