RS3 Pro Issues after latest firmware update
1027 2 2024-8-8
VIDEOMAN77
It had been a while since i used my RS3 Pro. So when I opened the app, it of course prometed to do firmware on it and all the connected devices.  After doing so I have several issues happening that werent there before:
  • DJI Assist App will not detect the RS3 Pro. I've tried multiple cables and ports, as well as uninstalling apps and reinstalling them.  Its not working.
  • I have Canon 5D Mark IV balanced perfectly. however after mintues of usage the Roll axis starts drifting.  If i double tap the trigger it returns to position, but after i pick it back up and start using it again it starts drifting.
  • Half of the time when i try to run the calibration it fails.  Autotune fails everytime.
  • After about 2 hours of messing with it...now one of my motors appears to be having issues.  When I tilt the gimbal side ways the camera should roll and level itself out, now it just hangs there, then when i move it back to center and try to go the other way, it locks up for a second.
  • Focus Motor hasn't worked since firmware update
  • Still can't get the Raveneye to detect my camera signal.
Thanks for any info you can give me.  I'd try to do a firmware reinstall but I don't know how to do that.
–Caleb
Finallty got AutoTune to work here are the settings it set.  Stiffness on the roll axis is 100%
2024-8-8
VIDEOMAN77
Here is a video showing the roll issue.
2024-8-8
robotfist
Just curious, were you dealing with firmware 01.05.00.00 for your RS 3 Pro? And are you still having the same issues?
2024-8-24
