DJI Thor
Flight distance : 13602 ft
Orsa Posted at 8-10 13:07
[view_image]
Activation failed. Check and try again Activation failed. Error code: Server error (-2). Check and try again. Contact DJI Support if the issue persists)
HI there, we apologize for any inconvenience caused. After our investigation, it seems the activation failure might be due to a device firmware issue. We kindly request that you bring the remote controller to our authorized service center (ASC) for further inspection. Technicians there will conduct a comprehensive assessment and provide you with a suitable solution. If you have any questions, please do not hesitate to consult with the technicians, or you can also reach out to us. Thank you for your understanding and cooperation! |
