miguelgarse
Flight distance : 1029222 ft
Hello!
I think I'm facing to the same issue. I had the DJI Mini 3 fly more combo (dron and remote controller), which worked perfectly in both bands (2.4Ghz and 5.8Ghz), but recently I crashed the dron... I sent the crashed dron to DJI Official Support, and they gave me a new one... just the dron... so yesterday I paired the dron with the remote controller (something that has not been easy), but after a bit suffering... both are connected.. buuut the problem now is that the connection is weird... when I turn on the dron and the RC, they pair and unpair several times, it take too much to get paired (with the other dron the connection was really fast)... and apart from this, investigating a little bit, I saw that when dron and RC get paired, if I open the three-dots menu and try to change the transmission band, I have noticed that 2.4 band doesn't work... it only can work in 5.8 band... of course I have try the Auto band mode, but in that case it lose the connection, trying to get it back, but it simply can't.
I have try everything (or at least I thing so)... I have upgrade, downgrade and refresh firmware version in both dron and RC using DJI Assistant 2. I have paired unpaired a lot of times. I have clear cache in RC... but I'm afraid I can't find the solution
And I think this is not a problem about the place where I am. This is the same place where I have fly a lot of times and there is no new or special interference or obstacles.
The problem of this is that flying in just one band is a bit dangerous... |
