djiuser_qXgSmNo51q8d Posted at 8-18 13:44
The firmware version of osmosis pocket 3 is 01.04.08.02
The sound when using only the transmitter for recording is not picking up recording at all
When I connect the device to computer to hear on play back no sound is playing but the file Is showing that it’s playing but no sound as though there’s some internal problem with the microphone
May I confirm if you mean you press the Record button on the left side of the transmitter to enable internal recording. Then, import the audio file into a computer with a Type-C cable to check whether the sound is normally recorded in the file. And the recorded audio is abnormal, right? In this case, we recommend you send the device back for inspection. http://www.dji.com/support |
