CDKJnr
South Africa
Hi All. We've started to deploy our first few Dock2's ( and it's awesome ) but we found some concerns, and would like some feedback on this. The DOCK 2, mainly used for BVLOS operations via FlighHub2 we feel should still provide the local base set featuers of like the RC-PRO. We found that it does not provide a local RTSP output, and also no way of remotely changing network configurations. So our workaround was to now install the RC-PRO also at the DOCK location, always connected, always on, setup to push the RTSP into the requiered systems. BUT, we also found that the RC-PRO once the aircraft lands in the dock, ends the RTSP session, and can only be restored via local intervention. This defetes the entire purpose of having the DOCK2 as a remote system :-(
Since the DOCK2 now becomes the "controller" this surely should be possible to send out RTSP directly from the dock, showing the live video from the drone?
Our main issue is the RTSP stream from the DOCK2 locally.
Is this possible, or maybe in the roadmap?
Thanks
