Deficiencies of the DJI Goggles 3 together with the Air 3
356 3 8-22 11:48
fansd61733ff
I have purchased the Air 3 and the Goggles 3. But I am not really happy with the goggles because of the following deficiencies:
1. Cruise Control does not work with goggles.
2. The HD reception is not as good as with the RC 2 controller. Maybe this would be better if you could change the antennas.
3. I cannot switch from 1x to 3x zoom, although I have programmed the C2 switch on the RC 2.
4. The screen of the RC 2 controller is turned off when I fly under goggles. There should be a way to switch between goggles and RC 2.
5. I don’t get the same flight records like flying with the RC 2. I would especially like to get the flight path.
6. In the goggles I don’t see the landing pattern of the quadcopter when I tilt down the camera.
7. The constant display of the message: "Aircraft not connected to DJI Fly" is useless. Maybe it can pop up once a minute for a few seconds, but not constantly block the view.
On the right side in the middle of the screen is a circle with a 1.0x inside. The manual of the goggles says about this Zoom Ratio:
If the aircraft supports Explore Mode, and Explore Mode is enabled in the shooting mode, the current zoom ratio will be displayed. Scroll the dial on the goggles camera view to adjust the camera zoom.
I don’t understand this. Please explain it.
As you can see there are a lot of deficiencies of the DJI Goggles 3 together with the Air 3. I hope DJI can fix this with an update.
8-22 11:48
Peter_E
I can confirm all these problems. DJI, please fix it!
8-23 07:53
Peter_E
No reply from DJI?
8-29 07:31
Eminmon
Flight distance : 2227884 ft
Argentina
if we're lucky, maybe all those features be implemented on future firmwares
9-2 16:38
