glenrs
Hi,
I'm looking at the scan angle metadata from my lastest flight. Values range from -36 to 112. I understand that the scan angle is usually the combination of the angle of the laser plus the angle of the drone, at least for lidars that are fixed to the bottom of the drone. Hence, you can get scan angles outside the FOV spec. However, the L2 is mounted on a gimbal, which should keep the lidar pretty close to nadir. Presumably, the IMU's are mounted in the lidar body. Can anyone tell me then why the scan angle falls outside the [-40,40] range that would be expected?
Additionally, is there any way to convert these scan angles to laser-only angles, perhaps with the IMU data?
