DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
Please perform the following troubleshooting steps and tell us your feedback.
1. Check whether the gimbal is in Follow mode.
2. Check whether the aircraft has been collided.
3. If the camera screen is skewed whether in the image transmission and the original footage are both skewed, please follow the troubleshooting steps listed below:
a. First check the wind velocity in the flight environment: The stabilization effect will be affected by strong wind. We recommend changing to another environment or waiting for some time before taking off again.
b. Please check with the control sticks: If the control stick is pushed with too much force, the aircraft speed will be high, which reduces the stabilization effect. It is recommended to push the control stick gently.
c. Please check whether the propellers are damaged or deformed. If there is any damage and deformation, it is recommended to replace the propellers. Verify that the two propellers on the same motor have the same batch number. Please use two propellers with the same batch number.
d. Ensure that the aircraft is not in S mode when flying.
e. Remove the microSD card from the aircraft. Place the aircraft in a stable status and restart it.
f. Connect the DJI Assistant 2 software for firmware updating (if the firmware is not the latest version) or refresh the firmware (if the firmware is the latest version).
Please keep us posted. Thank you. |
