MrFooz
I'll try to truncate as much as I can - long story...
I have a P4 standard that has been sitting a while. I want to start using it again. I was using a Asus Nexus 7 with GO4 V 4.3.37 and it always workd fine. The Tablet is OLD and Batt is weak - run it's race! So I bought a cheap WalMart ONN 11 PRO. It's actually very nice, feature rich, 64 BIT V13 Android OS. Can't beat the price.
I loaded GO4 onto it, the latest version. It WILL NOT connect to the craft! I've read a bunch of very good posts here and trid MANY cables. It just say 'Disconnected' and I cna't get it to work.
If I use the old Nexus 7 and older version of GO4 it works fine - just like it used to.
What could be the problem? Is it the ONN Tablet? I've made some tweaks I saw on YT and even installed the SW with a APK installer vs just 'loading' it.
Also, I've read about some newer Federal reg that will force me to use an add-on device to be 'compliant' with something. Will loading new SW brick the craft till I get this little black box thing?
I've even DL's some older versions of GO4 (4.3.54, 4.3.25, 4.3.37) none of them let it connect. I don't trust the Batt on the Nexus or I'd just return the ONN Pro to WalMart.
Can you help here?
Thanks
M
