Air 3 Timelapse shot settings
644 6 8-29 13:19
Avatex
Flight distance : 945807 ft
Hello I want to shoot my first timelapse with the Air 3, I will be shooting a landscape with a sunset.
Should I shoot in auto mode instead of pro because of the changing lighting or the preset at the start pro mode is better?
I've seen very good timelapse using the 70mm camera I think I will do the same.
8-29 13:19
Drone.Hunter
Flight distance : 4537612 ft
Kazakhstan
Manually, otherwise it will always be light.
But I just shot a video and then sped it up to give me more creative options.
8-29 19:54
Avatex
Drone.Hunter Posted at 8-29 19:54
But I just shot a video and then sped it up to give me more creative options.https://youtu.be/Zh4qMyFRPpo
Great shot! thanks for the reply I did think it would change the lighting but I didn't think about the fact it would keep it at the same level the whole sunset on another setting than manual will do tonight.
8-30 06:02
Drone.Hunter
Kazakhstan
We look forward to your results.
8-30 21:41
DJI Gamora
Avatex Posted at 8-30 06:02
That's great to know you have gotten the needed assistance.
If you have any other questions, kindly let us know. Thank You, have a great day!
8-30 22:13
DJI Gamora
Thanks for sharing this information! It will definitely be helpful for others on the forum. Have a great day! Thank You!
8-30 22:13
Geo_Drone
Flight distance : 2866296 ft
Romania
Depends...Usually is made with Aperture priority if your drone have variable AP....as Air 3 does not have it, you should use manual mode with fixed ISO and variable SS and WB....
Use a program for stability at editing to fix any movements of drone....for example this was a test we made in order to see if an Autel Evo 2 Pro goes in same position after it comes to change the battery...was flawless, same position at centimeter level.
9-1 22:37
