Avatex
Flight distance : 945807 ft
fichek Posted at 8-30 07:06
There is nothing you can add to Avata 2 to make it more durable. By adding weight you're decreasing performance (especially if it's offsetting its center of gravity), likely decreasing signal (especially with carbon fiber), and adding more kinetic energy into your crashes. The only thing you can theoretically achieve is to redirect that energy into another section of the drone which might break a less expensive part, but if it's gonna break, it's gonna break, and Avata 2 frame is pretty much a single part anyway.
The only "protection" worth having is a filter on your lens, because damaging a filter is much cheaper than damaging the actual lens.
I had the filters in my cart unsure if I should buy them right away but thanks to you I'll buy them right away, after all you said and my very light research beforehand I don't see the point in bulking up my drone to make it thougher that's right.
I never even thought about the fact that adding weight also adds more kinectic energy to the crash great insight thank you |
