SSD Error. Changing SSD mode or formatting the SSD card ir recomm...
539 2 2024-9-1
fansbe0ad866
Flight distance : 12687 ft
Brazil
Hi,
My Inspire 2 does not recognize the SSD card and does not format them. I have done the firmware update several times and the problem is not resolved. I've already reinstalled the app and used Assistant 2 on PC and MacBook.  I don't know what else to do. I've seen that a lot of people have had this problem in the past, but I haven't found any solution here. Can anyone help?
2024-9-1
fansbe0ad866
Brazil
2024-9-1
DJI Stephen
Hi there, sorry to hear about the issue you experienced. May I know if you would be able to manage a cross-test with another SSD or Inspire 2 to see if it is related to the SSD or aircraft? If it is the SSD's issue, you may send it back to our service center for further service.
You can start an online repair case here https://www.dji.com/support/repair if needed.
2024-9-2
