=DUH=
Flight distance : 5218209 ft
fichek Posted at 9-2 07:28
Remote ID is bluetooth based, and often transmitted only from the controller, so unless you're standing or flying within like 10m of other pilots, there would be nothing for you to see.
"Remote ID is bluetooth based"
no, it can be Bluetooth or WiFi based. I will do a test which one DJI is using on Avata 2, but on Air 3 it was WiFi as far I remember from my first test a while ago
"often transmitted only from the controller"
no, it's not broadcasted by controller, EASA/FAA require broadcasting by the unmanned aircraft. (it would be pointless to transmitt via controller, because how would they identify a drone that is f.e. spotted 10km deep in a restricted area?). The position of the pilot is transferered to the drone, and broadcasted together with all the other data from the UAS.
"flying within like 10m"
no, Bluetooth 5 Longrange is up to 1km. As it does only require a low speed unidirectional data transfer, the distance of 1km can be easy achieved with a few mW TX power. Almost all new mobile phones can receive that data.
