Avata 2 battery ejecting! I didn’t expect this!!
329 13 9-3 00:49
DAFlys
A bit of a PSA to check your battery insert method
9-3 00:49
A J
Flight distance : 15283773 ft
That's a concern! I always double check it's clicked in before every take off.
9-3 01:18
DAFlys
A J Posted at 9-3 01:18
Certainly not the drones fault,    just users being sloppy.
9-3 01:32
Iczeman
Flight distance : 8824416 ft
Czechia
Ejecting battery is a standard feature of all DJI FPV drones.
I have experienced that with original FPV (spent 2h searching it in a corn field as battery rejected) also experienced it with Avata 1 and now expecting the same with Avata 2 which you just confirmed
It's much more funny to search your drone without battery as Find my drone of course is not working, of course not working Turtle mode etc.
I could recommend a thermo-camera as if batteries and drone are still HOT it makes searching a lot of easier
Happy searching  everyone and flight safety
9-3 01:58
fichek
Flight distance : 1211814 ft
Croatia
This is definitely user error, but even if you install it properly and you crash hard enough, you ideally want the battery to eject. Ejected battery = less kinetic energy in subsequent tumbles = less broken Avatas.
9-3 02:16
A J
DAFlys Posted at 9-3 01:32
Absolutely - it certainly highlights the importance of preflight checks.
9-3 09:00
Zyxel
Poland
Iczeman Posted at 9-3 01:58
The Avata 2 implements the detection of battery errors, but it is not implemented properly as you can see in the OP's video because the clicked-out battery has not triggered any error messages and the drone was allowed to take off.
It gets worse than that!
Even a fully clicked-in battery can experience an error when the drone stops abruptly (e.g. after hitting the distance limit) yet the drone does not initiate the Return To Home (RTH) after detecting that error and its engines can continue to function for half a minute after that error appears.  See the video in the thread below and notice the battery error displayed in its final moments:
https://forum.dji.com/forum.php? ... =317213&pid=3398414
9-3 11:57
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Ensure the battery is securely locked into place. A loose fit can cause it to eject during flight or impact. I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
9-3 18:58
DowntownRDB
Flight distance : 1722 ft
Nice find and a great bit of PSA.  Always a good item to have on your pre-flight checklist.
9-4 03:25
The Duck
Dude isn't strong enough to make the battery go click every time.     Sorry., I couldn't help myself!
9-4 06:36
DAFlys
The Duck Posted at 9-4 06:36
He did say he had someone else load the battery.
9-4 08:22
Antdrones
Flight distance : 987654 ft
Why don't you just buy a battery guard?
9-6 06:11
DAFlys
Antdrones Posted at 9-6 06:11
Completely unnecessary you just need to make sure the battery is plugged in properly.
9-6 23:25
Antdrones
DAFlys Posted at 9-6 23:25
Oh ok that makes sense
9-7 11:52
