Avata 2 stopps flying - newbie Q
187 5 9-4 00:45
ClaesD
Sweden
Hi Forum, I am brand new to this....My Avata 2 is really hard to get started, there is no logic to when it starts and when it decides to stop flying, often after 1-2 minutes it just lands. I am close to a restricted area and my DJI Fly on Android is acting weird as well...any thoughts on this?
9-4 00:45
EPICDRONEFLIER
Try a different phone if possible. Try connecting the goggles to your phone and check for updates.
9-4 07:15
ClaesD
Sweden
EPICDRONEFLIER Posted at 9-4 07:15
I will try that, thanks
9-4 07:21
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Please try steps as below;
1) Make sure your firmware are up to date on all your device.
2) Follow the steps in this link to linking and activating your device A Beginner's Guide to DJI Avata 2
If issue persist please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
9-4 19:22
yogi053
Flight distance : 26104915 ft
What about trying a different location as well? Restricted area might, just might be causing a bit of interference.
9-5 00:11
Sean-bumble-bee
Flight distance : 15997 ft
Perhaps  upload the .txt flightlogs for two relevant flights to
https://www.phantomhelp.com/LogViewer/Upload/
Re the phone, install a screen capture app on the phone and use it to capture the wird behaviour, then o=post a vide o of it.
9-5 04:56
