Va1entin2
Flight distance : 1135686 ft
Romania
fgange57 Posted at 9-10 00:07
I have been looking at several of my previous screen recordings, I can see that I get "near ground warning" that starts when I am closer than 5 meters above the ground. Looking at the distances where these warnings appear, they seem to be very accurate. My point is therefore that when you press "Update home point", is should be possible to program a message of e.g. "To update height above ground you have to descend to a position closer to ground" - to get this low ground measuring system. DJI seem to have very good programmers, so I sincerely would not think this should be to much of a programming task. You can of course not use any other measurement above ground, because neither GPS or barometric pressure is accurate enough.
Although this is very easy to do technically, DJI will never do this, because it would mean breaking the law in Europe and probably in other countries.
European law obliges the drone to stay at a maximum of 120 m (500 m for others) from the take-off point, not from the home point. In a single flight, a drone can have only one take-off point and a lot of home points
They have a sufficient precision of 0.5m.
Why don't the height above ground update when Home Point is updated?
Because they are two different things. The take-off point is not a home point and can only be changed... by another take-off
