Pocket 3 Focal Hunt
593 3 2024-9-8
Fishycomics
I am showing my Review video  where I am with the Pocket 3 outdoors and the camera can not  Lock on it focus hunts,  What can I do to prevent this, is there a Fixed focus setting (no) or any way to  lock it.  I do not use tracking at all. I should use it  the next time I am not even on product review continuous view.
thanks
FISH
As the other vid  a well
2024-9-8
DJI Natalia
Hi there, thank you for reaching out! It is recommended to use Activetrack to focus on a person or object. You can follow the steps below.
1. Basic ActiveTrack: When using Osmo Pocket 3 standalone, double tap on the subject in the screen to trigger basic ActiveTrack. A green target frame will Appear around the followed subject. If there are both face and other objects in the double-tApped area, face will be prioritized for following. When connected to DJI Mimo, drag to select a target on the phone screen to trigger ActiveTrack;
2. Face Auto-Detect: In the Face Auto-Detect mode, tracking automatically starts when the recording begins and a person is recognized.
3. Dynamic Framing: In the Dynamic Framing mode, use the 5D joystick to select the target position in the composition to start tracking.
4. FT (Selfie): Enable FT (Selfie) in the Control menu. FT (Selfie) automatically triggers when the gimbal rotates to the selfie orientation.
To exit ActiveTrack: Press the 5D joystick once or tap outside the tracking frame on the screen.
Kindly let us know the outcome after using Activetrack. Thank you
2024-9-10
Fishycomics
When its released you will see the camera did not Hunt, it is on certain scenes,
2024-9-10
Montfrooij
Flight distance : 2845026 ft
Thanks for the tip, I would like to use the P3 for static scenes too, but I will have to dive into the focus thing.
My current P2 has 'one time focus' option, which does work well for static scenes.
2024-9-26
