Shutter speed
1169 7 2024-9-9
djiuser_urgIZMJ5zQYP
As this seems a fairly basic drone was wondering if you can control shutter speed and iso manually, or does it operate in an auto exposure mode?
2024-9-9
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
The camera of DJI Neo supports Auto mode and M mode. It is able to adjust EV value in Auto mode, and adjust shutter speed and ISO in M mode on the Camera settings page in the app. I hope this helps.
Should you have any other questions, kindly message us here for assistance. Thank you.
2024-9-9
fans7af45d35
Flight distance : 1253 ft
DJI Diana Posted at 9-9 01:18
Hi there,
but only if connected to remote controll?
2024-9-9
relaxosmo
Flight distance : 901965 ft
Hungary
Please make it possible to adjust sharpness settings and 4:3 recording (gyroflow stabilized), when using only RC-N3 remote.
Instant buy, if it will be possible!
thanks!
2024-9-9
DJI Diana
fans7af45d35 Posted at 9-9 01:19
Hi there,
Yes, it can only be done via remote control as it cannot be adjusted when using a mobile phone.
Should you have any other questions, feel free to contact us. Thank you.
2024-9-10
MARTINEZX
Poland
Why you can not change using phone?
2024-9-13
DJI Diana
MARTINEZX Posted at 9-13 13:36
Hi there,
The shutter speed can only be changed when using RC. Rest assured we will treat this as feedback and send it to the relevant team for their evaluation.
2024-9-13
EwaKrzyzanowska
Flight distance : 108196 ft
Poland
Hi all,
I am an owner of Mini 4 Pro. Recently I decided to start fun with long exposure and manual/pro settings. One of other users recommended me to use super long exposure for one photo shooting and that's now I discovered some settings are missing for my Mini 4 Pro. My shutter max is 2'' .... there should be 2.5'' 3.2'', 4,5'',6'',7'',and finally this 8''. My MAX shutter is 2'' visible (PRO mode).  ISO 6400 is also missing.
Other problem is missing Fly Assistance /sensor view, that others have.
Can anyone help me and release me firmware solving missing options.
It's a second firmware I am facing.  First time was timelapse that was turning off after second (solved with releasing for me beta version of firmware).
_____Edit: SOLUTION FOR WHOEVER WILL BE FACING SIMILAR PROBLEM:
The problem could be solved with updating to V01.00.0700 that appeared recently on my controller.
The next issue I was facing was with V01.00.0700 installation error (reoccuring on my controller) stopping on 33% with installation failure.
I tried also multiple times via Assistant 2 (Consumer Drones Series) also with error. Cleared catche, restarted Mini 4 Pro, restarted laptop, reinstalled Assistant 2.
Changed battery to full. Still the same error.
Solution was to change battery PLUS to normal battery. It went smoothly and x2 faster as it should.
After installation the shutter got extended and I can see my expected 8''. ISO also got 6400 instead of max 3200.
If after installation you still cannot see the 8'' - make sure you are set to photo > single and 4:3 to get 12MP pix. (with 48 will not work).
I hope this troubbleshooting will help someone..
Happy flying!
2024-10-1
