RS3 Mini is not charging above 96%
737 3 2024-9-9
fanse2f3b029
Flight distance : 2981932 ft
Russia
Hi everyone!
Recently I've noticed my RS3 Mini is not charging above 96%. Also when I remove the cable and then plug the cable back in, the charge percentage shows 100% for a second and then drops back to 96%.
What is the problem? Does the gimbal have the battery calibration functionality?
2024-9-9
DJI Stephen
Hi there, just for your information:
1. To slow down battery aging, extend the battery life, and avoid battery overcharging, the gimbal will slow down/stop charging if the battery level reaches a certain value (about 95%) while charging.
2. The charging strategy is different for batteries with different battery level. If the battery level reaches a certain value (about 95%), trickle charging will be triggered (charged at low current), so the charging time will be extended.
You can disconnect the charging cable, let it stand for one minute, or charge the battery after used. Thank you for your attention.
2024-9-10
fanse2f3b029
Russia
DJI Stephen Posted at 9-10 01:45
Thank you for your reply! Does DJI supply replacement batteries for RS3 Mini?
2024-9-11
DJI Susan
fanse2f3b029 Posted at 9-11 11:42
Hello, we do not sell individual batteries on our website. If there is a problem with the battery, you can send it back for repair.
2024-9-11
