Rocksteady in 4k/120
355 5 9-9 12:05
relaxosmo
Flight distance : 776585 ft
Hungary
I have OA3 and discovered that Rocksteady is more wobbly in 4k/120p mode than in 4k/60p.
4k60p is perfectly smooth, like a gimbal, while 120 is not so stable. Yes, i walk exactly the same in both cases.
I like to ask if this is the situation also with OA4? Or does it have more processing power so 4k/120 is also supersmooth?
Thanks a lot!
9-9 12:05
johansenfoto
Flight distance : 1180089 ft
Norway
Good question. I will try it out if I remember tomorrow
9-9 14:15
relaxosmo
Hungary
Thanks man!
9-9 22:03
Fishycomics
Just the Action 4 in 4K RS, if we need to compare the A3 and A4 together I will later today
9-10 04:33
relaxosmo
Hungary
Thank you!
Unfortunately from 0:40 i see the same wobbling at 100/120p mode, which i discovered on my OA3.
So no upgrade here.
Thanks again!
9-10 04:38
Fishycomics
relaxosmo Posted at 9-10 04:38
Thank you!
So no upgrade here.
You're welcomed.
9-10 04:52
