Ascending and descending while stationary using the MC3
605 6 2024-9-9
Duke56
Flight distance : 1927093 ft
Using the MC3, can the Avata 2 (or Avata 1 for that matter) go up or down in altitude while not moving?  Upwards movement of the MC3 while the A2 is stationary just moves the camera up.  I know you can do that quite easily using the RC3.
2024-9-9
fichek
Flight distance : 1378789 ft
Croatia
You can either push the little joystick up/down, or point the camera up/down and when an arrow u/down appears you will see if you keep pointing the arrow will look "selected", just press throttle and it will move straight up/down.
2024-9-9
Duke56
fichek Posted at 9-9 14:40
I'll give it a try.  Thanks.
2024-9-9
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Kindly refer to user manual page 36 for making aircraft ascend or descend at an angle. DJI Avata 2 user manual
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-9-10
Duke56
DJI Gamora Posted at 9-10 22:30
Hi there,
Thank you DJI Gamora.  That doesn't address my question though.  Having the Avata 2 go up or down in altitude while not moving is the question.  Going up or down while the Avata 2 is moving is not an issue.  I have shots I want to take having the Avata 2 go straight up or down while not moving.
2024-9-11
fichek
Croatia
Duke56 Posted at 9-11 02:56
It does answer your question on page 33:
And then again on page 39:
And in the answer I provided 2 days ago above.
2024-9-11
DJI Gamora
fichek Posted at 9-11 11:14
[view_image]
Thank you for sharing your resolution. This sure will help other users whose having the same issue. Have a safe flight always!
2024-9-15
