LV_Forestry
Flight distance : 4726654 ft
Latvia
"DJI suggests to use ortho vs oblique"
I don't understand what that means. DJI's recommendations for using their equipment are so so, you have to sort them out.
The choice of putting the sensor at NADIR or obliquely depends on the scene, its relief, its obstacles... If you ever see a guy who tells you to do one method rather than another in 100% of cases because it's better, move on. It's up to you to try it based on what you have. With LiDAR anyway there is no huge interest in putting it obliquely. Maybe to find points under structures, bridges, very dense canopy...
Yes indeed there are 5 paths, you don't have to do them all. You have to select the ones you want to execute. Once again, it's up to you to make your own experience. You will see that there are scenes that require more images than others to obtain an optimal photogrammetric reconstruction. In general where the texture is very homogeneous.
