DJI DL 75 mm lens compatible with I2/X7?
735 3 2024-9-14
LuftBuidl
Flight distance : 13613051 ft
Hello,
does anyone know if the new DJI DL 75 mm lens is also compatible with the Inspire 2 and X7 gimbal, or is it dedicated only to the Inspire 3 and X9?
Thanks in advance!
Best regards,
Stefan from southern Germany
2024-9-14
Mike9129
Flight distance : 4112812 ft
Theres a new firmware update to make it compatible with the I3, so im not sure if itll be natively compatible with the I2.
My own copy should be on by the end of the month, I will try this out for you and report back if someone else doesnt come back to you about it first.
2024-9-16
LuftBuidl
Mike9129 Posted at 9-16 00:32
Thanks alot! I cannot wait! :-)
I stumbled upon this I3 firmware update information as well and thought this is not good news for those who just have the Inspire 2.
2024-9-16
DJI Wanda
Hi, there
We have tested Inspire 2 + Zenmuse X7 gimbal with 75mm lens, although the screen can be displayed normally, aperture/shutter/ISO can be controlled normally, AF/MF can be controlled normally, no ground shaking, App no abnormal error message, but this lens compared to the other DL-mount lenses is obviously heavier (a safety hazard), during the flight of the head camera, we can not guarantee the image quality, stabilization performance and flight performance. However, this lens is significantly heavier than other DL-mount lenses (a potential safety hazard), and we cannot guarantee the image quality, stabilization and flight performance of the gimbal camera during flight, so we do not recommend this lens for use with the Zenmuse X7.
Thanks for your understanding.
2024-10-15
