DJI Natalia
Ponderosa Flyer Posted at 10-3 07:16
I'm having the same problem. It occurs when I use the RC2 controller. The controller is set to English, as everyone above has stated. I tried rebooting and reconnecting, and that doesn't work - as everyone above has stated. Any updates on this issue?
*** edit ***
I tried removing all the languages from the RC2 controller except English. Still same problem. Connect to RC2, Drone speaks in Mandarin, and continues to speak Mandarin after disconnected. Connect to Phone, Drone speaks in English, and continues to do so after disconnected This is clearly a bug related to use with the RC2 controller.
Hi there, thank you for reaching out and we do apologize for the trouble caused. Kindly follow the below steps to set the languages :
- Power on the remote controller, slide down the screen, and select "Settings" > "System">"Languages&input">"Languages", then press and hold the target language and drag it up to the top to modify the language. If a supported language is not shown under the language list, please click【Add Language】to add the target language and then hold the target language and drag it to the top.
If the issue persists, kindly share us a video recording showing the issue for us to check further with our engineering team. Thank you for your understanding. |
