DJI Connection issues with the paired RC-N3 controller
12Next >
8226 50 2024-9-15
Shaun_D_1884
Flight distance : 93645 ft
Hi , has anyone lese had major issues in trying to connect and fly their DJI Neo using the supplied RC controler (RC-N3) supplied in the 'Fly more' pack?
I bought the fly more pack, which included the new RC-N3 controller and after numeroua attempts to set it up, it will not connect to the aircraft at all! and I can't see what the problem is. When using the DJI Fly app (latest version installed)  I select the 'Connect with RC only' under the connection guide, then it will only get to page 1/3 'pairing the Remote controller' and that's as far as it gets ? the pairing proceedure and it won't go any further than that (step 1) - it will not connect to or recognise the aircraft. I read somewhere that as it's part of the flymore pack the aircraft and controler should arrive already paired, but this doesn't seem to be th case as it asked for me to slect an aircraft type straight off and the took me down the 'pairing' route.
So after a week I have a nice little paper weight instead of a drone! and clumps of hair lying all over my desk, pulled out in utter frustration !
Has anyone any ideas what I'm missing or is it a faulty RC unit ?
2024-9-15
DJI Diana
Flight distance : 2408 ft
Hi there,
thank you for reaching out.
We apologize for the inconvenience. If you purchase a DJI Neo Combo, the remote controller is already linked to DJI Neo upon shipment. You can use them directly after activation upon powering on. In other cases, please refer to the following.
Link DJI Neo to a remote controller:
1. Power on DJI Neo and the remote controller before linking, and keep the distance between DJI Neo and the remote controller within half a meter.
2. Connect the remote controller to your smartphone, then open the DJI Fly app.
3. Tap Connection Guide on the bottom right corner of the DJI Fly app, select the device, then follow the on-screen instructions to press and hold the power button on the device until the voice prompt sounds, and wait until the linking is complete after tapping “Pair”.
4. After linking successfully, the app will turn to the liveview.
Please keep us posted. Thank you.
2024-9-15
fans1426f453
i have exactly the same problem and the online chat session from dji cannot resolve it
2024-9-16
Keffir
Denmark
Me too! I Have the exact same problem ?! Really ...ty that you can't connect... ive tried everything and nothing works ?!?!?
2024-9-16
infobrowningmedia.com.au
Flight distance : 1605656 ft
2024-9-21
mikaspuiterij
na een update hebik ook dit probleem code 80004 kan niet meer vliegen soms wel op open terein mar niet in een open gebied waar bomen en water zijn
2024-9-21
DJI Diana
mikaspuiterij@h Posted at 9-21 15:34
Hi there,
Could you please confirm which drone model you are using? Please adjust the remote controller heading to raise or control the aircraft to fly away from obstacles and thus avoid the signal obstruction.
2024-9-21
djiuser_g1PonhLyYiyV
DJI Diana Posted at 9-15 19:41
Hi there,
Hi, when I tap on the connection guide and go to select aircraft model, the Neo is not shown as an option.
Is there a download to sort this!
The Neo is added to my account, and works fine on its own or using an iPhone 12, just not my N3 controller.
All firmware has been updated.
Thanks
2024-9-23
DJI Diana
djiuser_g1PonhLyYiyV Posted at 9-23 02:49
Hi there,
Before we further assist you, may we confirm if you purchased a DJI Neo Combo? If yes, the remote controller is already linked to DJI Neo upon shipment. You can use them directly after activation upon powering on. In other cases, please refer to the following.
I hope this information is helpful. Thank you.
2024-9-23
DJI Diana Posted at 9-23 02:56
Hi there,
The Neo is not shown as a device to select when the phone is connected to the controller. It is when only the iPhone is used.
2024-9-23
Antdrones
Flight distance : 1253035 ft
another reason not to get the neo..
2024-9-23
Sathyanarayanan Subramanian
Switzerland
The problem is with the cable.. I too had the problem and it just worked when I used a Samsung cable...
The cable is broken which is supplied in the remote...
2024-9-25
r.e.w.e.x
Czechia
Sathyanarayanan Subramanian Posted at 9-25 11:22
Hello, I apparently have the same issue as you. Have you somehow overcame this issue ? Thanks for any answer
2024-10-1
Jbrd
I have same issue, however, Neo and remote were purchased separately. Brand new though. Cannot link the remote. Seriously discouraged. First Dji drone too. Not happy. Tried everything. Firmware updated on remote. Tired other cables. Tried DJI Assistant. Nothing works. Hoping someone posts something that will help. Or just going to send it back and share off dji.
2024-10-16
Jbrd
Hi there,
This does not work!
2024-10-16
Nate Thompson
I fixed this issue for myself by swapping out the USB-C cable that was included with the RC-N3 controller with a Samsung branded USB-C cable. I own a Samsung Galaxy S23 and the USB-C cable that was included with the remote doesn't work for my phone. DJI may want to look into this and do some more thorough testing with actual devices. I coiled up the 3ft cable that I'm using, so it's not as pretty looking, but I can now download the firmware update and control my drone.
2024-10-17
Logisticalstyle
Flight distance : 688061 ft
Jbrd Posted at 10-16 15:36
I just got my separately purchased RC-N3 today and had a lot of trouble getting it to work with my Neo. The instructions are not good at all. I was able to get it working by pairing the controller to the Neo. First I had to do updates on the controller and the Neo using the DJ Assistant app on my computer. Then I followed the instructions listed above by DJI Diana and it all worked.
2024-10-18
DJI Diana
Logisticalstyle Posted at 10-18 09:45
Hi there,
We appreciate the update provided and are glad your issue has been resolved.
Feel free to contact us if you have any other questions.
2024-10-18
fans6fa640bf
Malaysia
Hello, after the recent farmware updgrade, my rc n3 (got with fly more combo)is not connecting with dji neo. I can use the contrller to manually fly the drone but no camera view. Need a solution.
2024-10-23
Ronald Pinto
Uruguay
fans6fa640bf Posted at 10-23 23:54
Hello I have the same issue.
I can use to fly the DJI neo, but don't show anything with cam and the view cam show a message "controller it's not connected"
2024-10-24
Ronald Pinto
Uruguay
Morning finally it's working but I downgrade to the version.02 in the DJI neo
2024-10-26
Robert753
Ronald Pinto Posted at 10-26 06:53
How do you downgrade firmware to version 2? I have the same issue
2024-10-28
Robert753
Brand new neo, and remote... Will not connect tryed everything, but the remote connects to my other drones just fine. So frustrating!
2024-10-28
Ronald Pinto
Uruguay
Robert753 Posted at 10-28 19:38
using the DJI Assistant app on my computer.
https://www.dji.com/global/downloads/softwares/dji-assistant-2-consumer-drones-series
2024-10-29
Ronald Pinto
Uruguay
Robert753 Posted at 10-28 19:40
Try to downgrade the firmware to .02 version that's works for me.
2024-10-29
Buddika Manaram
Flight distance : 26637 ft
Sri Lanka
I have exactly the same problem but after the update and the online chat from DJ cannot be resolved and I change cable and mobile still cannot be resolved.My Rc still On but not connecting.
2024-11-3
Ro Wilson Queddeng
Philippines
I have the same problem, just bought the fmc neo 2 days ago and i still can't figure it out. Can someone help me? Thanks
2024-11-7
DJI Diana
Ro Wilson Queddeng Posted at 11-7 04:39
Hi there,
We apologize for the inconvenience. Could you please confirm whether you have attempted the steps outlined in reply #2?
2024-11-8
DJI Diana
Buddika Manaram Posted at 11-3 09:20
Hi there,
2024-11-8
lsmith77
Switzerland
Some issue here. Also I am on the latest OSX version which isn't letting me install the desktop DJI Assistant app that was suggested above.
Nevermind, accidentally got the RC-N1 confused with my RC-N3
2024-11-9
Man Well
Hi ,
I had my DJI Mini 2 Combo. I decided to buy DJI Neo because of its nice Features, now I'm trying to use my RC from Mini 2 to DJI Neo but I couldn't connect my Neo to RC! Is there anyway or procedure how to connect Neo to RC!? I heard that DJI Neo can be use with some DJI Remote control!? Please advise. Thank you!
2024-11-9
DJI Diana
Man Well Posted at 11-9 14:43
Hi ,
Hi there,
Are you using DJI RC-N1 with DJI Mini 2? If so, it is not compatible with DJI Neo. If you want to know whether the accessories of the aircraft are universal/compatible, such as batteries, remote controls, chargers, etc., please refer to the article below for help.
https://support.dji.com/help/content?customId=en-us03400006882&spaceId=34&re=US&lang=en
2024-11-9
Richard Rauen
Just bot the DJI RC 2 and the DJI Neo.  They will not pair.  I've downloaded the latest firmware.  When "connecting to aircraft" the controller will try to connect then it will show "Unable to connect to aircraft" Next I  held  the Neo power button down for 4 secs but the aircraft did not beep.  Any ideas?
2024-11-13
dashforth
Flight distance : 319951 ft
I had the same problem after the recent upgrade to V.01.00.0400.  The firmware upgrade appeared to have gone OK and I could fly using my phone but RC-N3 that cam with the combo would no longer connect. I did a firmware refresh using DJI Assistant 2 just in case - but still no connection with RC-N3. It would appear that the firmware upgrade breaks the pairing. My RC-N3 was already paired originally because it came in the combo. I had to manually re-pair controller and Neo and now everything works OK again.
2024-11-14
dashforth
Are the RC and Neo definitely paired? Please note that this is a separate process from simply switching the Neo on. You later have to put it into pairing mode by holding down the on/off button.
2024-11-14
djiuser_dGzgwagFHiiH
Hi there I'm same problem this morning. Controller rcn3 not connecting to phone Neo will connect normally in fly app but I have tried everything. It was working Sunday
2024-11-14
DJI Diana
Richard Rauen Posted at 11-13 12:56
Hi there,
We apologize for the inconvenience. Please refer to the following and see if you can isolate the issue.
Link DJI Neo to a remote controller DJI RC 2:
Please keep us posted on the progress.
2024-11-14
DJI Diana
djiuser_dGzgwagFHiiH Posted at 11-14 18:35
Hi there,
We apologize for the inconvenience. Before we proceed with further assistance, could you please confirm which mobile device you are using?
2024-11-14
Elky64
What a hot mess! I updated my Neo's firmware today (Nov 15/24) and wasn't able to connect the RC-N3 controller to it. Swapped the cable with the one from my Potensic Atom drone and now it connects, but no live feed!?!?!? Downgraded the Neo's firmware via the DJI Assistant 2 (Consumer Drones Series) program, that's installed on my PC, and now the RC-N3 controller connects. This needs fixing A.S.A.P.!!!
2024-11-15
dashforth
Elky64 Posted at 11-15 14:46
When I upgraded the firmware it broke the pairing. You need to re-pair. A bit of a pain but it worked for me.
2024-11-16
12Next >
