Backing up/Exporting flight Routes On RC Plus Inspire 3
476 1 2024-9-16
djiuser_IRBHV49fatKJ
Austria
We are halfway through a big client project that involves many repeatable route flights with the RTK 2 Base station capturing the seasonal changes at several locations over the period of a year.
  • Has anyone backed up flight routes on an SD card and re-imported them onto the same or another RC Plus on the inspire 3?
  • Also is anyone having accuracy problems with the RTK 2 Base station and stored flight routes after the latest update v01.00.07.00?
Thankyou
2024-9-16
DJI Wanda
Hi, there
Inspire 3 supports exporting flight routes created in the remote controller as a KMZ file and importing them into other Inspire 3 remote controller.
1. Importing KMZ file:
1). Tap “Flight Route” in the homepage of the DJI Pilot 2 app.
2). Select “KMZ Import” in “Flight Route Library”.
3). Open the folder where the KMZ file is located (the folder name can be customized), and select the KMZ file for import.
2. Exporting KMZ file:
1). First, create a new folder (to save the KMZ file).
2). Enter DJI Pilot 2 and tap “Flight Route”.
3). Select KMZ file in “Flight Route Library” and tap the share icon.
4). After selecting the corresponding folder, tap “Export”.
When using the D-RTK 2 Mobile Base Station, it is necessary to confirm that the locations of the D-RTK 2 Mobile Base Station that generates routes and performs route re-flights have not changed, that it is installed securely and tightly, and that it is installed with an accuracy of centimeter, and to confirm that the positions of the coordinates on the D-RTK 2 Mobile Base Station App are the same.
2024-10-26
