dji integra goggles bind fpv controller 3
1246 11 2024-9-19
justdevs
Flight distance : 211693 ft
Denmark
hi,
Why can i not bind the dji integra goggles to the fpv controller 3 and why is it not stated that the fpv controller 3 is not compatible with any googles.... soooo sad....
2024-9-19
DJI Gamora
Hi there,
Thank you for reaching out. Could you confirm if you are trying to connect your DJI Goggles Integra with DJI FPV drone? If yes please take note that the remote controller that support both of the mentioned device are only DJI RC Motion /DJI FPV Remote Controller 2.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-9-19
justdevs
Denmark
DJI Gamora Posted at 9-19 03:56
Hi there,
Hi,
I have the following hardware.
DJI integra googles
DJI fpv controller 3
DJI O3 system
The goggles bind just fin to the O3 system. BUT the Controller 3 will not bind to the goggles.
FYI the hardware is running the last update available.
2024-9-19
Antdrones
Flight distance : 1253035 ft
they are comparable with the goggles 3
2024-9-19
Antdrones
justdevs Posted at 9-19 04:08
Hi,
you need goggles 2 if you want to bind w goggles integra
2024-9-19
justdevs
Denmark
Antdrones Posted at 9-19 06:45
How would that work? Bind the goggles 2 and the bind the other goggles?
2024-9-19
Antdrones
justdevs Posted at 9-19 07:15
Sorry meant remote 2, my bad my bad
2024-9-19
Antdrones
if you want to bind rc 3 to goggles it has to be goggles 3, if you have rc2 you can bind with goggles 2 or integra
2024-9-19
justdevs
Denmark
I have dji integra and Dji controller 3 they don’t bind.
I have tried with a controller 2 now and that doesn’t work either with the DJI integra..
2024-9-19
DJI Gamora
Hi,
Thank You for the update. Kindly take note that DJI Goggles Integra only compatible with DJI FPV Remote Controller 2. DJI Goggles Integra is not compatible with DJI FPV Remote Controller 3.
If you want to use DJI O3 Air unit it is compatible as below;
1. DJI Goggles Integra/DJI Goggles 2/DJI FPV Goggles V2 > DJI FPV Remote Controller 2
2. DJI Goggles 3 > DJI FPV Remote Controller 3
2024-9-20
djiuser_hmoTTVojQ1ND
Nigeria
Is there a plan to release firmware update to allow compatibility with Integra Goggles and FPV Controller 3? As of this post there is still no compatibility, which I find ridiculous.
The Integra goggles can bind with Avata 2; the Avata 2 can work with FPV controller 3; but Integra Goggles do not work to Controller 3.
This is very misleading and seems to be a simple fix.
2024-11-21
djiuser_h7YzjIy47j9x
Philippines
DJI Gamora Posted at 9-20 00:41
Hi, will there be an update for Controller 3 to be Compatible to Goggles 2 and Integra?
2024-12-9
