Action 5 Pro Stabilization in UVC and RTMP Issues
123Next >
6538 113 2024-9-19
fansac9d1f4e
Edit3 October 17, 2024: NOT fixed with the new firmware!
I took inspiration from Zheph and put 4 recordings into one video to show the comparison between different modes. These are all HorizonSteady:
Hi,
The DJI Osmo Action 5 Pro is still experiencing worse stabilization when in UVC and RTMP mode when compared to a recording. Same issues in Action 4.
UVC (Webcam) is the worst, followed by RTMP, with best results when it's just a regular recording.
I have made a recording, time marked for each mode I am testing:
Edit2:
Please see the livestream I just did today, which has chapters for each device I switch to (Action 5, Action 4, Pocket 3). I start out with the Action 5 Pro in RTMP mode on the highest stabilization setting available - HorizonSteady. It is worse than the Action 4 at the same settings. When I switch to UVC on Action 4, it is even worse.
Thanks!
Edit:
By the way, this is on the latest firmware - updated day of release.
2024-9-19
fansa6ff3a6c
Thanks for doing this test. This issue means the camera won’t work for live streamers. DJI, can you enable stabilization in UVC and RTMP modes, or at least make it a toggle? As the original poster noted recording mode works as expected, but the lack of stabilization in UVC and RTMP modes is a big problem.
2024-9-19
Yanncd FrenchStreetMedic
Hi, is 1080p in 30 fps the only resolution choice for Webcam mode ?
If yes that would be weird.
There is nothing in specsheet about it.
And i could not find any video  with this information.
Thanks in advance for reply.
2024-9-19
fansac9d1f4e
Yanncd FrenchStreetMedic Posted at 9-19 21:07
I can't set it on the Action 5 itself but it should depend on what UVC profiles it has available. When I connect to a Windows computer I only saw options for 1080p 30fps and 720p 30fps
2024-9-20
ThisIsKurtIRL
A lot of live streamers are disappointed also there is still no 50/60 fps in UVC and RTMP
2024-9-20
fansac9d1f4e Posted at 9-20 01:47
I openned a thread on this subject, still no answer from DJI.
This might not be something they want to highlight.
Webcam / RTMP resolution settings
A deal killer for me.
2024-9-20
ThisIsKurtIRL Posted at 9-20 02:09
We should open a thread :"Disappointed, the list."
2024-9-20
fansac9d1f4e
I updated the original post with a livestream I did today showing the stabilization issues on the Action 5 Pro.
DJI has definitely improved webcam modes of other cameras, like the Pocket 3, by adding 4K... So we know they're capable of improving the webcam mode, but hopefully they can look at this thread and at least improve the stabilization and allow more choice for fps, as suggested!
2024-9-20
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
thanks for the feedback, we are looking into this issue.
2024-9-20
fansa6ff3a6c
Yes, it’s just hard to call the camera a pro model and get a worse feature set. Stabilization in particular has gotten worse year over year instead of better.
To summarize, please add the following:
Enable stabilization in UVC
Enable stabilization in RTMP
Allow us to select fps (24, 30, 60, etc)
Allow us to select up to 4k resolution
These would improve upon the action 4 and make this way more relevant to live streamers
Thanks DJI
2024-9-20
ThisIsKurtIRL
fansa6ff3a6c Posted at 9-20 08:10
pleeeeeease
2024-9-20
ThisIsKurtIRL
Tested both webcam and rtmp today and the video quality is very bad compared to the OA4
2024-9-20
Well, i was planning to buy two units, i'll rather wait for version 6 if nothing moves.
2024-9-20
SoWeQ
Denmark
I totally agree. A simple firmware update could have Solved this.
Give us options to change fps for rtmp and uvc!
Livestreamers out there are waiting for this to happen, let's make dji great on the live streaming market.
2024-9-20
banj
I am also having problems using my brand new camera in webcam mode.  I cannot capture the camera audio as well as video via UVC and the quality seems less than last generation action4?  Can we get a firmware update to enable 60fps via rtmp and webcam with this new PRO processor and sensor?
2024-9-20
Zheph
I have also done a test of every stabilisation mode of the Action 5 compared to the Action 2. As you can see, stabilisation is not working properly at all and is unusable for any form of action capture via UVC or RTMP. UVC also has no audio output, which is a big problem.
2024-9-20
ThisIsKurtIRL
Zheph Posted at 9-20 23:54
https://youtu.be/O1IPcVXA76s
Can this be fixed via firmware update DJI? Otherwise the camera is completely unusable to me and many live streamers and will be returning
2024-9-21
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. Unfortunately, Yes. 30fps is the only available resolution for webcam mode. I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-9-22
DJI Gamora
Hi there,
Thank You for reaching out. We are truly sorry for the inconvenience you are experiencing. The Osmo Action 5 Pro has multiple stabilization modes, each offering different stabilization effects and fields of view (FOV) based on the stabilization logic. If you need a wider FOV, we recommend switching to HorizonSteady mode. I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-9-22
fansa6ff3a6c
DJI Gamora Posted at 9-22 03:44
Hi there,
What we’re saying is the stabilization modes perform differently whether you’re recording versus in UVC or RTMP mode. In UVC and RTMP, the camera appears to crop in depending on the selected stabilization mode, but (if you watch the videos in this thread) clearly isn’t stabilizing the video. Can you please inform the engineers for a firmware fix?
2024-9-22
ThisIsKurtIRL
Hi there,
Its all broken, audio and stabe
2024-9-22
ShiroDJI
Czechia
ThisIsKurtIRL Posted at 9-22 04:56
after updating the app(android) RTMP doesnt work at all for me(only with streaming app for iphone MOBLIN) is it working for you guys?
2024-9-22
seany187
Can someone let me know if  Action 5 support RTMPS? Not just RTMP? I was thinking of buying it so I can use Gamechanger. I am not a fan of MEVO.
2024-9-23
ThisIsKurtIRL
seany187 Posted at 9-23 13:11
Just RTMP and thats not working very well
2024-9-23
seany187
ThisIsKurtIRL Posted at 9-23 13:15
Well that sucks.. they offer streaming, but don't seem to care about the software/firmware..
2024-9-23
stormense8
Flight distance : 40030 ft
Sweden
No Ultrarunner gona use this camera if DJI not fix the problem with Rockstedy+ in night
2024-9-23
DJI Gamora
ShiroDJI Posted at 9-22 10:56
Hi there,
Please send us a video recording of the problem. This will allow us to investigate further and provide you with the most accurate solution based on the specific issue you're encountering.
We are looking forward to your response for further assistance. Thank You
2024-9-24
DJI Gamora
fansa6ff3a6c Posted at 9-22 04:39
Hi there,
Thank you for your recommendations. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
Thank you for your support and understanding.
2024-9-24
DJI Gamora
Hi there,
Thank You for your feedback, we will forward this information to the relevant team for evaluation.
2024-9-24
DJI Gamora
stormense8 Posted at 9-23 14:14
No Ultrarunner gona use this camera if DJI not fix the problem with Rockstedy+ in nightVideo
Hi there,
Thank you for reaching out. RockSteady+: Compared with RockSteady, the edges of these images will be reduced slightly to obtain a stronger stabilization performance.
2024-9-24
ThisIsKurtIRL on Twitch
Used RTMP today and the footage looks terrible compared to when I used the OA4 https://kick.com/thisiskurtirl/v ... 8-bd7b-1e25b85b01c8
2024-10-1
fansac9d1f4e
Update with the new firmware - NOT fixed!
2024-10-17
fansac9d1f4e Posted at 10-17 11:33
which points? Still no 50/60 fps for me
2024-10-17
fansac9d1f4e
ThisIsKurtIRL on Twitch Posted at 10-17 12:12
Oh - I meant just the original topic in the title.
2024-10-17
fansa6ff3a6c
Still seeing the same stabilization issues in the updated firmware:
Action 4 in RTMP mode remains the gold standard. All Action 5 Pro modes (UVC and RTMP) are unstable.
2024-10-22
Please DJI, live streamers need you to help here, this camera is meant to be PRO. Please fix the issues ASAP
First 15mins of this video is the 5 on UVC. Unwatchable. I had to turn it off and switch to a camera thats 8 YEARS OLD https://www.twitch.tv/videos/2281626344?t=00h05m30s
2024-10-22
ShiroDJI
Czechia
I am checking once a week if the are able to fix at least some issues with RTMP, so far they just dont care... Last msg I got from suport was they will check and update me ASAP, IT WAS 3 WEEKS AGO xD its just sad, they are not competent enough
2024-10-23
I know live streaming isnt a priority but not asking for anything complicated, just fix it and make it as good as possible
2024-10-23
Up, it needs to be solved
2024-10-31
fansac9d1f4e
Bumping this up as it is still not fixed in the new firmware.
2024-11-10
123Next >
