Always on display - Turns off
453 7 2024-9-23
In the sun
Flight distance : 1709583 ft
Why does the always on display setting turn off the display ?
After a few minutes it turns to time setting on battery power left.
2024-9-23
DJI-ytao
DJI R&D Squad
Flight distance : 1209413 ft
Hi, Are u referring to not show display, always show the liveview?
2024-9-23
In the sun
DJI-ytao Posted at 9-23 02:31
what is that ?
I have activated always on display.
as i said, after a few minutes it changes to remain power left.
2024-9-23
DJI Natalia
Hi there, thank you for reaching out. Could you please share us a video recording demonstrating the issue for us to have a better understanding on this and check further for you? Also, kindly try restarting the device and see if it helps.
Looking forward to your response. Thank you!
2024-9-24
In the sun
I have reset the camera and problem persists. The display shows a hours remaining counter when it "turns off into standby"
However the problem is worse than that as bluetooth voice commands also are not accepted when screen is in this mode.
This is like the OA 4 which had to have a firmware update to fix.
update see below
2024-9-24
In the sun
so it turns out the control icon is the opposite to what it say, if you have not green icon OFF.
Then the display does NOT turn off.
duhh
2024-9-24
DJI-ytao
DJI R&D Squad
In the sun Posted at 9-24 04:57
always on display OFF will display nothing but black screen  off when recording in 3s(the param you are setting next line)...
2024-9-25
In the sun
DJI-ytao Posted at 9-25 00:38
yes but it also turns off the LCD when in standby and shows the time.
I think the wording is very ambiguous.
2024-9-25
