Feature Suggestion - Rotate
529 18 2024-9-24
Tender
Flight distance : 1236309 ft
I'm working on a small project that includes about 15 sites, where I need a perfect rotation.  I don't want to circle something like POI.  I need the camera to stay in the same spot and just do a rotation.    I'm using crusie control now and I need about 2:15-2:30 minute rotation.  So, I set my cruise and I am getting pretty good.  But I keep thinking it would be nice to hit a feature (like POI) that says 'rotate', set the time required and hit "go'.  I would have a perfect rotation every time, excactly the same.   You could still fly up/down/back/forward while it is rotating, like POI.
Just a thought.
2024-9-24
_SoP_
Flight distance : 1012552 ft
Nice idea, I already have some scenes in mind where I could make use of this feature as well. Second that!
2024-9-24
Sean-bumble-bee
Flight distance : 15997 ft
Can't you reduce the maximum yaw rate to very low values and then just apply full rudder or create you own joystick movement stop for yaw.
2024-9-24
DAFlys
+1 great idea.
2024-9-24
Tender
_SoP_ Posted at 9-24 22:02
Do you use cruise control?  If not try it.  I Use it lots, it works for rotate, but I usually have to try a couple times to get my speed where I want it.
2024-9-25
Tender
Sean-bumble-bee Posted at 9-24 23:11
I reduced it a low as possible, still way too fast.  Cruise control is the best way but it takes a couple tries to get the speed right where you want it.  I'm just dreaming/thinking out loud, about a 'rotate' function.  You never know, maybe they might add it cause of me.  I'll be famous. lol
2024-9-25
Zoooom
I'd like it if you could push a button that made the drone carry on in the current direction, but allowed rotation.
I have difficulty spinning the drone to the side and carrying on the current vector, since the drone often brakes.
2024-9-25
Tender
Zoooom Posted at 9-25 07:16
My Phantom 2 had 'course lock' that did just that.  I miss that feature.
2024-9-25
Sean-bumble-bee
Tender Posted at 9-25 07:24
A lot has been lost as DJI have 'improved' their apps.
Ok so the minimum yaw rate is still too fast and that's a pity but it is my recollection that I have been able get very slow 'rates' with very careful movements of the relevant joysticks. If you create your own joystick travel-limiter you should be able to get a constant yaw rate.
I would suggest that the best control will be achieved by setting the EXP value to 0.5 which give a straight line graph and predictability of joystick-movement vs changes-in-the-drone's-response.
BTW way I am not trying to talk you out of your idea, it seems well liked, I am just being realistic about the likelyhood of DJI introducing the feature.
2024-9-25
Tender
Sean-bumble-bee Posted at 9-25 08:44
I just use cruise control, it works the best.  I use Cine mode to get a nice rotation.  Get a nice rotation going and lock it.
2024-9-25
Sean-bumble-bee
Tender Posted at 9-25 08:53
I just use cruise control, it works the best.  Get a nice rotation going and lock it.
Ahh, so are you saying that cruise control can give a fixed yaw rate ?
I don't have an applicable drone with which to experiment.
2024-9-25
Mobilehomer
Flight distance : 18150351 ft
Sean-bumble-bee Posted at 9-25 08:55
Sean, CC is GREAT!! Not only speed, but direction as well. I have set it to curve, climb and diagonal. At different times, of course. You can also change direction while maintaining steady speed.
2024-9-25
Tender
Yes, it locks any stick input, plus you can "stack them', for lack of a better term.  Move forward at 3/ms and lock it, add in a rotation without touching the forward stick , it holds the forward and adds the rotation, add in a rise and it holds all 3...or more.  Plus, you can lock a movement and fly freely while that stick movemnt is locked.
2024-9-25
Tender
Mobilehomer Posted at 9-25 10:38
Yeah, it's a great feature.  I don't always remember to use it for stuff.  I just remembered I could do the rotation and lock it.
2024-9-25
Serg SSA
Flight distance : 14496650 ft
Russia
This function is available in the GO 4 app and all drones with this app can fly like this. Very convenient, it's a pity that it's not available in Fly
2024-9-25
OneSnark
Flight distance : 665968 ft
Cruise control is a favorite feature for me.  Very useful for "longer" runs where you want constant speed. . . .or simply don't want your fingers to get tired from steady pressure.
Note that I can cruise control a straight line; and "input" a up/down left/right course correction without affecting the "go forward" cruise control
2024-9-25
Sean-bumble-bee
Tender Posted at 9-25 11:00
Cheers .........
2024-9-25
DJI Gamora
Hi Tender,|
Thank you for your recommendations. Please rest assured that we will forward your feedback to the related department for evaluation. In the future, we will optimize and improve the product or service based on user comments.
Thank you for your support and understanding.
2024-9-25
bJako
Flight distance : 2530407 ft
Estonia
OneSnark Posted at 9-25 12:22
Or start with "go forward", then add "turn" and then add "go up" to cruise control...
2024-9-26
