DJI Tony
Mariusz Goch Posted at 9-26 07:44
Hi,
To be clear problem with location is in official version downloaded from this site https://www.dji.com/pl/downloads/djiapp/dji-fly and tested on latest version: 1.14.2 and many more before.
Last version that I was able to run was 1.12 and now it stopped working.
Hi there.
The reason why you need to enable location permission to access the album is that when QuickTransfer transmits, it needs to determine whether the country supports 5.8GHZ transmission. For example, Japan does not allow 5.8G. If you do not determine it, using 5.8g will violate local regulations. Therefore, you need to obtain location permission to determine the country and then determine whether 5.8G is supported.
However, even if there is no GPS, you can still obtain location information and locate it through the network. You can try using the latest version of DJI Fly app to connect to the network and see if you can access the album. If it still doesn't work, please send us a screenshot of your settings interface for further analysis. |
