Shutter Speed
773 2 2024-9-26
Fedorovic
Flight distance : 2451 ft
Belgium
Hi hi,
Can I set the "Shutter speed" with the DJI Fly App?
2024-9-26
DJI Natalia
Hi there, thank you for reaching out. Regrettably, the Shutter speed is not adjustable when DJI Neo is in Mobile App Control. When DJI Neo is connected to goggles or remote controllers, the Shutter speed can be modified manually.
Thank you for your understanding and support.
2024-9-26
EwaKrzyzanowska
Flight distance : 108196 ft
Poland
Hi all,
I am an owner of Mini 4 Pro. Recently I decided to start fun with long exposure and manual/pro settings. One of other users recommended me to use super long exposure for one photo shooting and that's now I discovered some settings are missing for my Mini 4 Pro. My shutter max is 2'' .... there should be 2.5'' 3.2'', 4,5'',6'',7'',and finally this 8''. My MAX shutter is 2'' visible (PRO mode).  ISO 6400 is also missing.
Other problem is missing Fly Assistance /sensor view, that others have.
Can anyone help me and release me firmware solving missing options.
It's a second firmware I am facing.  First time was timelapse that was turning off after second (solved with releasing for me beta version of firmware).
_____Edit: SOLUTION FOR WHOEVER WILL BE FACING SIMILAR PROBLEM:
The problem could be solved with updating to V01.00.0700 that appeared recently on my controller.
The next issue I was facing was with V01.00.0700 installation error (reoccuring on my controller) stopping on 33% with installation failure.
I tried also multiple times via Assistant 2 (Consumer Drones Series) also with error. Cleared catche, restarted Mini 4 Pro, restarted laptop, reinstalled Assistant 2.
Changed battery to full. Still the same error.
Solution was to change battery PLUS to normal battery. It went smoothly and x2 faster as it should.
After installation the shutter got extended and I can see my expected 8''. ISO also got 6400 instead of max 3200.
If after installation you still cannot see the 8'' - make sure you are set to photo > single and 4:3 to get 12MP pix. (with 48 will not work).
I hope this troubbleshooting will help someone..
Happy flying!
2024-10-1
