Regarding Mavic 3 Enterprise Calibration After Battery Swap
563 3 2024-9-30
djiuser_sm0f3GYnuzYv
Brazil
Good morning,
I have a question about the Mavic 3 Enterprise. I've noticed that after calibrating the drone with one battery, it works fine. However, when I swap the battery, although it continues to function, it becomes a bit more "sensitive" and the 360-degree rotation seems slower. After another battery swap, without recalibrating, the drone becomes even more unstable.
Is it necessary to recalibrate the drone after every battery swap, or is there a setting that allows it to calibrate automatically?
Thank you for your attention.
2024-9-30
Johnnokomis
Flight distance : 14031719 ft
Which calibration are you talking about exactly? Compass calibration, IMU calibration, gimbal calibration, camera calibration or something else?
2024-9-30
Labroides
Flight distance : 26781877 ft
Why are you recalibrating anything?
You are probably referring to the drone's compass?
No .. it's not necessary to recalibrate the compass after a battery swap.
The drone doesn't lose its compass calibration.
There no need to recalibrate the compass ever, unless you add/remove accessories or modify the drone.
You can safely fly for years without recalibrating anything.
2024-9-30
pspec
Flight distance : 2570446 ft
Switzerland
...the 360-degree rotation seems slower.
The more zoom is set, the slower the drone turns.
2024-9-30
