DJI Gamora Posted at 10-6 01:27
Hi there,
Thank you for reaching out. DJI Neo is light and compact, and relies heavily on its vision positioning system for stable flight, especially in environments with no or weak GPS signals. Vision positioning is highly dependent on ambient light and ground textures. In low-light conditions or areas with plain and uniform ground textures, the drone may not be able to hover stably. Therefore, we recommend that you shoot using DJI Neo in environments with ample light and distinct ground patterns.
Hi, thank you for the reply. The light was fine that day, it was around 7 a.m. with direct sunlight, and the GPS signal was strong, as you can see from the flight data report. Based on your explanation, I suspect the issue may have been caused by the plain and uniform texture of the beach sand.
But even if the hover was unstable, we should still have had control over it since I was using the RC. Why did it drift so fast? There should be at least some safety measures in place. I couldn't land it even though I held the left stick down on the controller.
Anyways, thanks again for the reply.
