I have had a couple of landings where one side of propellers powers down while the other side stays on for a second longer causing the drone to fall over. Anyone else have a similar issue?
What procedure are you using to land your bird? I always land and hold the left stick down in the center, straight down center. Props shut down all at the same time in a couple of seconds. Have never had a tip-over.
I've never used auto-land. Whether using the RTH function, free-flying, running a Ground Station (waypoint) or POI flight, I always take control of the craft and land manually.
