Circle Mode - Height
686 4 2024-10-12
dannyknightuk
It would be great if there was a height option (low/medium/high) option for circle mode on the DJI Neo for the next update
2024-10-12
Pagemakers
Flight distance : 414377 ft
Currently your option is manual take off and then engage circle at any height you like.
2024-10-12
Blériot53
Flight distance : 7075748 ft
If you use the RC-N3 controller in conjunction with the Neo you can do exactly that already. Or if you control it with DJI Fly from your smartphone.
2024-10-12
DJI Natalia
Hi there, thank you for reaching out. May I confirm the remote controller you're using with your DJI Neo? If you're using DJI RC-N3, you will be able to choose the height as per reply in #3.
Looking forward to your response. Thank you!.
2024-10-13
Pagemakers
You don’t need the controller. It can be done using the phone only.
2024-10-13
