Beeblebrox42
Mine also came with the OA5 adventure combo and states model number AC2CH on the bottom and has the 'white' DJI logo on the top which a review indicated distinguishes the new case - the older one is black embossed it suggested. I assume charging is the same as the previous case = Red LED 0 to 20%, Yellow 20 to 80%, Green 80 to 100% and then LED off when reach 100%. So if taking out when turning green, it would only be at 80% and need to wait until light out as has been found above.
Manual for the old one here: https://dl.djicdn.com/downloads/DJI_Osmo_%20Action_%203/AC/0916/DJI_Osmo_Action_3_Multifunctional_Battery_Case_Product_Information_v1.0.pdf
Whether the old case works with the new batteries though I don't know, or even a mix of batteries. I remember my old AA battery charger didn't like a mix of batteries and would only charge to the max of the lowest mAh so I also wonder if mixing in the case may have a similar effect? |
