sultangris01
camera might be getting hot and causing issues, like machoman said the max flight time youre ever going to get is around 15 minutes and the camera will stay cooler due to air movement, 28 minutes sitting still might simply be overheating it as it wasnt designed to record for that long. I have no idea if hes right about the photocamera custom reason limiting the max possible recording time, ive never heard of such a thing and it sounds like BS to me but it could possibly be true. It would be faster to drain your batteries by actually flying, or if outside weather prevents it just let it sit on your kitchen table or floor with the motors running at an idle, or just dont worry about it, they will self discharge when whatever timer you have set in the app, choices from 2-10 days i think are the self discharge timer triggers, the self discharge process takes 2 days to go from 100% to 60% once it starts. |
