Rajbhag
Flight distance : 213763 ft
Singapore
i dont know if this is a stupid question or not. can the dji neo be flown at the french alps.
2024-10-16
Mavic57Minis
Flight distance : 4212949 ft
As long as your take off point is no more than 2000 metres. See spec in screen shot. Weather and wind being suitable at the time.
2024-10-16
MrDinB
Flight distance : 67923 ft
Not really if you are planning to take it up high. It doesn’t have an ability to handle strong winds and still has some GPS:navigation issues.
2024-10-16
DJI Gamora
Hi Rajbhag,
DJI Neo is light and compact, and relies heavily on its vision positioning system for stable flight, especially in environments with no or weak GPS signals. Vision positioning is highly dependent on ambient light and ground textures. In low-light conditions or areas with plain and uniform ground textures, the drone may not be able to hover stably. Therefore, we recommend that you shoot using DJI Neo in environments with ample light and distinct ground patterns.
I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-10-16
Rajbhag
Singapore
Mavic57Minis Posted at 10-16 07:31
in this case if I take my DJI Mini 4 Pro would be a better choice right, but there is one problem that on the return journey from the French alps I have to make 2 days stop in Abu Dhabi this is what worrying me.
2024-10-17
Rajbhag
Singapore
MrDinB Posted at 10-16 07:31
yes what you are saying is correct and I have the DJI Mini 4 Pro which is a better choice but the problem is Abu Dhabi customs as I have to make a 2 days stop over
2024-10-17
Rajbhag
Singapore
DJI Gamora Posted at 10-16 23:42
Hi Rajbhag,
thanks for the information that you have given, I can use my DJI Mini 4 Pro but the problem is Abu Dhabi customs as I need to make 2 days stop over
2024-10-17
DJI Gamora
Rajbhag Posted at 10-17 05:35
Hi Rajbhag,
Sorry to hear that, please do check with the airlines and local authority of the country you are planning to fly. I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
2024-10-19
