Depp
Flight distance : 1868796 ft
Surferboy Posted at 10-22 03:02
Hi Depp,
Thank you for the reply. I did compile with OSD set as HD format under the OSD section and additionally I used the preset "OSD for FPV.wtf..." Is there a chance I could look at your CLI? Or I could send mine maybe? I bet its some small.
# rxfail
rxfail 7 s 2000
# master
set gyro_lpf1_static_hz = 312
set gyro_lpf2_static_hz = 625
set dyn_notch_count = 1
set dyn_notch_q = 500
set gyro_lpf1_dyn_min_hz = 312
set gyro_lpf1_dyn_max_hz = 625
set acc_calibration = 92,22,6,1
set dshot_bidir = ON
set motor_pwm_protocol = DSHOT300
set motor_poles = 12
set failsafe_procedure = GPS-RESCUE
set vbat_max_cell_voltage = 440
set vbat_warning_cell_voltage = 300
set yaw_motors_reversed = ON
set small_angle = 180
set gps_sbas_mode = AUTO
set gps_ublox_use_galileo = ON
set gps_set_home_point_once = ON
set gps_rescue_min_start_dist = 10
set gps_rescue_min_sats = 5
set gps_rescue_allow_arming_without_fix = ON
set pid_process_denom = 4
set simplified_gyro_filter_multiplier = 125
set osd_vbat_pos = 2305
set osd_rssi_pos = 129
set osd_link_quality_pos = 2177
set osd_rssi_dbm_pos = 2209
set osd_tim_1_pos = 3567
set osd_tim_2_pos = 3535
set osd_flymode_pos = 2114
set osd_throttle_pos = 162
set osd_vtx_channel_pos = 161
set osd_current_pos = 2272
set osd_mah_drawn_pos = 2240
set osd_craft_name_pos = 2082
set osd_gps_speed_pos = 3439
set osd_gps_lon_pos = 19499
set osd_gps_lat_pos = 19467
set osd_gps_sats_pos = 3179
set osd_home_dir_pos = 2170
set osd_home_dist_pos = 3183
set osd_flight_dist_pos = 3407
set osd_compass_bar_pos = 330
set osd_altitude_pos = 19595
set osd_warnings_pos = 2424
set osd_avg_cell_voltage_pos = 2337
set osd_battery_usage_pos = 35137
set osd_disarmed_pos = 2392
set osd_nheading_pos = 45
set osd_flip_arrow_pos = 65
set osd_core_temp_pos = 3503
set osd_efficiency_pos = 231
set gyro_1_sensor_align = CW180FLIP
set gyro_1_align_pitch = 1800
set gyro_1_align_yaw = 1800
set craft_name = Explorer
profile 0
# profile 0
set iterm_relax_cutoff = 20
set p_pitch = 52
set i_pitch = 63
set d_pitch = 68
set f_pitch = 80
set p_roll = 47
set i_roll = 59
set d_roll = 63
set f_roll = 76
set p_yaw = 50
set i_yaw = 63
set f_yaw = 76
set d_min_roll = 41
set d_min_pitch = 45
set simplified_pids_mode = OFF
profile 1
profile 2
profile 3
# restore original profile selection
profile 0
rateprofile 0
rateprofile 1
rateprofile 2
rateprofile 3
# restore original rateprofile selection
rateprofile 0
# save configuration |
