AlSo-Fotografie
Flight distance : 644341 ft
Bussty Posted at 10-23 16:46
They are really nice! 2 Questions... is that really a thing, in Free Pano you can only have JPEG? also are any of those 70mm Panos? If you ever have the time I would be so grateful if you could find a scene that fits a 24mm and take a single shot then switch to 70mm and do a Free Pano covering the same view (should be over 9 frames required) then if you could post both the 24mm single shot and stitched 70mm shot (or post a link so we can stitch ourselves) would be so useful. Just want to compare a composite taken using Free Pano using the 70mm compared to single 24mm frame. Should be like flying around with a Sony A7RV. Many thanks
For me as a photographer its always better to have more dynamic range. Especially in such high contrast situations.
Much better then free pano with raws would be a bracketing option.
Even if i had my Canon R5 up in the air. This would be my way to go. On a bright sunny day, a single raw is more then enough!
@Bussty
So in this case each pano (manual) is the result of 3 to 4 stiched images with a 5 bracket exposure.
For some maybe a overkill, for me standard (better to have it and dont need it).
Maybe 2 to 3 exposures will be enough for an contrast silhouette look
Sure ill test a 24mm single shoot and a 70mm stitched pano.
I did this already. In can say its a differend look.
24mm looks more streched and the 70mm is more compressed.
I also will test the wideangle attachement and show the result✌️ |
