Sir Edward K
The Maps and RTH works off of the GPS on the Phantom. Your Home Point will be set while you are on the ground and have adequate GPS signal for the Phantom (not your phone or iPad Air). When the home point is set you will see it on the map. You can track yourself on the map (as long as you cached it before hand when you had wifi service). You can RTH if you need to as it will return to the Home Point that was set previously. But if you walk around or move you will not be able to reset your home point to your new position because you don't have GPS on your device connected to the controller.
I hope that is what you were asking about. |
