NO Sphere panorama only independent pictures
200 9 10-26 19:24
HCastano
Flight distance : 154203 ft
Mexico
Today was the 4th time I tried to take/create a Sphere Panorama but ended up with with only the independent images on the card.
On this particular ocasion, I had just received the low battery warning, but since the drone was 1.5 metters above the ground and 3 meters in front of me I canceled the return to home warning (first warning), I then took/started the panorama and landed the drone afterwards (on previous ocasions I did not get a low battery warning, kept flying for a couple of minutes and took aditional pictures before landing).
I'm guessing this time the drone was not able to stitch/merge all the images before it shut down (low battery), so I ended up with an html file and a panorama folder with the image number (DJI_...._0142_D.html and 001_0142)...
My question is:
Is there a way to create the sphere panorama with the DJI Fly app, remote (RC 2) or another app/program that does not require a purchase/license (free/online)?
10-26 19:24
Marius39
Flight distance : 427395 ft
Bonjour,
Si vous voulez assembler les images pour faire un panorama sphère sur un ordinateur, vous pouvez utiliser une application tel que PanoramaStudio 4.
Cordialement
Marius
10-31 09:01
MiniManiac
Flight distance : 1454524 ft
My video may be of help
10-31 12:48
fgange57
Flight distance : 522582 ft
Norway
If you are not getting a Sphere panorama (in the same folder as the videos), it is most likely that not all 35 pictures were taken.  It will always create the single photos during any panoramic shoot in a separate folder, but only stitch it together if all photos are present.
I have had incidents where the wind was too hard, so I got too much movement during the shoots.  All pictures up to then were stored and a separate html file was created telling which ones (but no stitched photo).  This is a normal behaviour.  Have you checked the number of photos, or did you create a screen recording to see what happened?  You can also look in the flight log to find out what went wrong.
10-31 14:58
HCastano
Mexico
fgange57 Posted at 10-31 14:58
Hello @fgange57,
The shpere panorama was taken indoors and I was able to take 2 pictures before landing the drone; I just double checked and I do have all 35 pictures on the corresponding panorama folder...
I haven't checked the log; but since all 35 images are there I guess I should be able to create the sphere panorama some way...
10-31 17:20
HCastano
Mexico
MiniManiac Posted at 10-31 12:48
Hello MiniManiac,
My issue is that the panorama was not created after the drone finished taking the 35 pictures; so unfortunately this did not help...
I do appreciate your time/answer...
10-31 17:24
HCastano
Mexico
Marius39 Posted at 10-31 09:01
Bonjour,
Bonsoir Marius,
Je viens de télécharger panorama 4, Je vais l'essayer...
Merci Beaucoup por votre aide
10-31 17:28
fgange57
Norway
HCastano Posted at 10-31 17:20
Hello @fgange57,
I agree with you that a sphere then should have been created.  I have never tried doing a sphere inside, but have you tried outside to see if the same happens?
Anyway, I will suggest before starting that you also start screen recording.  I have myself reviled a lot of things retrospectively that I did not see during the flight.  I also still mean it will be a good idea to look trough the flight log to see if any message may explain why the sphere was not created.
11-1 01:28
MiniManiac
did the counter finish the 35 pics and then continue counting as per the video
11-2 10:36
fgange57
Norway
MiniManiac Posted at 11-2 10:36
That's my question as well, because the only time I have gotten an html file was because not all pictures were taken. No stitching will take place then.  It is probably worth while checking the picture names in the html file and compare it with the actual photos in the folder (it may even happen that the last photo is crap).  And once again; I suggest you try outside (I really do not understand why you do it inside, as I will belive that could cause challenges when stitching the pictures together).
11-2 11:02
