What happend here? drone fall from skies
321 4 10-28 05:13
sysprep
Flight distance : 206946 ft
Argentina
I want to share with you the video I shot yesterday, I don't feel so confident to fly over the water anymore. It is worth mentioning that there was some wind. I thought that in case the drone tried to turn back on itself, the controller would correct. I saw that in a youtube video where a person tests the drone in high winds.
Flying with FPV remote controller in sport mode
10-28 05:13
DJI Gamora
Hi there, thank you for reaching out and we are sorry to hear about what happened with the drone. In a situation like this, the best course of action would be to submit an online repair request here: {https://repair.dji.com/repair/index}. If you need assistance with creating a ticket, you may contact DJI support at https://www.dji.com/support.
Once the drone has been properly evaluated by our technicians, the repair team will keep you updated on the assessment results. I hope this information has helped to clarify your inquiries. If you have any other questions, kindly let us know. Thank You!
10-28 19:36
sysprep
Argentina
There where no damage to drone, just fall into the ground. I used to fly over water and with this behaviour i dont feel comfortable. on any time it can just fall from skies. not so happy with this drone right now.
10-29 05:40
Montfrooij
Flight distance : 2845026 ft
Not sure if you still have the logs, but there are some smart guys around here that can analyse them.
11-6 00:59
Kain_niaK
Philippines
sysprep Posted at 10-29 05:40
You had a lot of momentum in one direction when you suddenly turned in to the other direction, the avata 2 is now moving backwards through air that it just made turbulent, as a result two of the 4 props don't have enough lift anymore and stall making the drone fall to it's side.
This is known as a yaw tumble. You can find countless examples if you goggles "yaw thumble avata".
There are two solutions for this problem:
1) FLy in such a way that you don't ever fly backwards through dirty air (air you made turbulent)
2) Buy different propellors like the HQ prop 3x3x3 props
11-7 04:52
