Phantom Menace
Looks like I wasn't wrong. The new SDK is out and all third party apps have to use it as the upcoming public release of the new firmware will require all apps (including 3rd party apps) redesign their apps or they will not function in the new firmware.
This is the new firmware that DJI Go will automatically download for you if you don't stop it.
For people just using DJI Go, you might not notice the new limitation, since DJI Go has already implemented this limit in the app. The new firmware now makes it impossible for any app to allow setting a maximum altitude of more than 500m. The third party apps were not bound by that limit before this new release, and you could set whatever maximum limit you want. If you update, and you use a third party app, you will now lose that ability.
I believe this is only the beginning. Future releases will include more restrictions as to range, speed, autonomous flight and more. Most of these have already been implemented in DJI Go, but again, I use a third party app (Litchi) and with the last release (Which I do not plan to upgrade from) I still have all the unrestricted abilities.
Why should I care if I can't go over 500m?
I live in the mountains. Many mountains around me are much higher than 500m. This limit is from where you take off, not 500m over the ground you are currently flying over. I would like the ability to rise up the side of a mountain and glide over the peak to see the view on the other side. I would be well within FAA regulations of under 400 feet (above the ground I am flying over) but I would be far above the 500m limit now imposed by DJI on all apps which is measured from where I took off.
I'm sure there are dozens of other valid reasons for needing higher altitudes. Others can chime in.
I bet in time, they lower it down the the FAA's suggestion of 400 or 500 feet. I bet they reduce the range to prevent anyone from flying by FPV further than line of sight (even in the middle of death valley of some other uninhabited area) and more.
You can put away those tin foil hats for now. It has begun for real. |
