L2 and Terra Processing Error
202 13 11-1 06:17
djiuser_D8RutBwjfjta
I  recently pefformed a large area scan at 300 feet elevation. i noticed a few passes on the stockpile did not register together correctly and are about 500mm apart in elevation.  I am wondering if it has to do with the gaps in the lidar on top of the mound?    i flew at a consistant height of 300feet but the big stockpile was about 150-200ft tall which meant the lidar didnt have enough overlap as it only would have been 100+- feet above the large pile.   Please see attached photos.  RTK is good
11-1 06:17
LV_Forestry
Flight distance : 4726654 ft
Latvia
What kind of base station are you using?
11-1 06:52
WELL, that brings me to my next question. I used a Trimble R12 base that i have used many times before with no issues. However this time i was getting this error shown on the photo.  i shouldnt be getting this error as i had full RTK connection the entire flight which is proven by the green line in DJI terra showing excellent RTK.          I could not get it to process so i downloaded a 1 second interval file from the nearest CORs station about 10km away. The files processed sucessfully with that other than this anomoly.
i have never had any issues with this setup but of course i did all of the software updates and now i am running into issues.
11-1 07:09
with RTK i didnt think you needed overlap in the lidar, however that is the only difference in this flight to others is that there is some missing overlap
11-1 07:12
LV_Forestry
Latvia
RTK during all the flight does not mean the correction is good. From what i can see there is a potential antenna reposition.
11-1 07:16
LV_Forestry
Latvia
djiuser_D8RutBwjfjta Posted at 11-1 07:09
Is the rinex file in the right format ? Covering the whole flight duration? Not farther than 25 km ?
11-1 07:18
LV_Forestry Posted at 11-1 07:18
Distance is 19KM to reference station.  i used version 2.11 but here are the options.
11-1 07:21
LV_Forestry
Latvia
djiuser_D8RutBwjfjta Posted at 11-1 07:21
Distance is 19KM to reference station.  i used version 2.11 but here are the options.[view_image]
Terra is theoretically able to read all. Choose 3.04 i use that and it works.
19km is ok.
Think about deleting the RTB file and replace rinex file extension by OBS.
11-1 07:28
going back to my R12 base perhaps it is not working as i may have the wrong RTCM version.   Should i be using 3 legacy?
11-1 07:28
LV_Forestry
Latvia
djiuser_D8RutBwjfjta Posted at 11-1 07:28
MSM must work as well.
11-1 07:29
LV_Forestry Posted at 11-1 07:29
turns out, i went back to 3.0 legacy on my trimble base and am no longer getting processing errors
11-1 08:20
LV_Forestry
Latvia
djiuser_D8RutBwjfjta Posted at 11-1 08:20
good to know
11-1 08:38
it would be nice if DJI Pilot 2 would give you a warning that something wasnt right if Terra doesnt like it. Luckily i pay for a CORS service so i had backup however that would have been an entire day of flying wasted when the controller was showing everything was perfectly fine....
11-1 11:53
LV_Forestry
Latvia
djiuser_D8RutBwjfjta Posted at 11-1 11:53
Pilot can’t see if something is wrong with base station coordinates. They are provided by the base station itself as a message. If the message doesn’t exist it will display 0000 as coordinates but that’s it.
11-1 12:48
